Case 830CK Western Diesel Caseomatic -Many Questio
Galen Ishman
07-19-2004 07:11:46
Hello, I just picked up a Western style Case 830 Comfort King Diesel with Case-O Matic. I need help!!
The tractor does not seem to move in the convertor mode. when I shift it to direct drive it will move. There is a pedal on the center of the floor below the dash that is froze up...what does this do?? The engine starts and runs well up to about half throttle then starts missing and belching black smoke. tractor does not seem to to be burning engine oil. Any ideas???
Galen Ishman
07-21-2004 05:54:23
 Re: Case 830CK Western Diesel Caseomatic -Many Que in reply to Galen Ishman, 07-19-2004 07:11:46
Engine diesel smoke problem solved.....The air cleaner was so plugged it couldn't breathe at all.
The tractor will still only barely move in the torque convertor mode but moves fine in direct mode. Where do you check the Caseomatic fluid level??
SHeiserman
07-19-2004 19:02:15
Did you give it a little throttle when you tried to move? It's normal for me to have to give it a little to get it going. Don't think it's a good idea to put it into direct to get rolling. That thing on the floor is a foot throttle-just the thing to get you rolling. As far as the black smoke goes, check your air cleaner, maybe it's a little plugged. I'm no mechanic, but those are the basic ideas. See if it takes off better in a lower gear while in low. Someone here can help you further if need be.
one more thing....
07-19-2004 19:07:32
 Re: Re: Case 830CK Western Diesel Caseomatic -Many in reply to SHeiserman, 07-19-2004 19:02:15
Be patient. Once you get these bugs worked out and figure out how to run it, you're gonna like it (c-o-m, that is).
