David Brown 770 Transmission lube
Mike Evans
07-19-2004 02:40:01
I have just purchased a David Brown 770A that has a little water in the transmission, I need to know what type lube it uses so I can drain and flush.
C. Amick
07-20-2004 09:58:53
 Re: David Brown 770 Transmission lube in reply to Mike Evans, 07-19-2004 02:40:01
The transmission, differential and hydraulic system are all part of the same system. According the the I&T Manual, it takes 24 quarts. The recommended lubricant, according to the manual, is 20W-40 motor oil. Change every 1,000 hours of operation. The filter is under the belly of the tractor.
Mike Evans
07-21-2004 02:13:50
 Re: Re: David Brown 770 Transmission lube in reply to C. Amick, 07-20-2004 09:58:53
Thanks for the reply. I even found the filter element and service manual locally, so I'm all set
