580ck front tire size and rating ?
Rick in Marylan
07-16-2004 22:02:56
All, What's the correct front tire size and rating for a 580ck Tractor/Loader/Backhoe? I believe the unit presently has 7.50x16 load range D (bias ply?)tires on it. Can I install left over 225-75-16 load range E radial tires on this ? If so will tubes handle the 80psi tire pressure required to support the load range E rating ? Also, are 14.9x24 R-4 tires the correct size and rating for the rear tires ?
