VA with worn tie-rod ends and king pins
Dale Olson
07-16-2004 21:33:59
My 1948 VA with standard wide front has seen a lot of hours. The tie rod ends and king pins have enough wear that it's starting to be a nuisense when mowing. What is the recomended way to fix something like this? For the tie rod ends is it possible to drill out the tie rod end and put in a bigger sholdered bolt? Build it up first with weld and then drill it out? Can the king pins be rebushed? How do I find someone who knows how to do this?
Thanks for any suggestions, Dale
