Paul You should be able to rig something up to test it. The cutout is a normally open relay meaning that when it is in your hand the contacts should be open. The contacts should close whenever the voltage on the generator side is higher than the voltage on the battery side (ie generator is charging) and conversely it should open whenever the voltage on the generator side goes lower than the voltage on the battery side (ie the generator is not charging probably due to low or no rpm). Your generator having only a cutout means that it is a 3 or 3rd brush generator. As such the 3rd brush picks up "residue" current from the armature and feeds it thru one of the field coils. The closer the 3rd brush is moved to the positive brush the more residue current it picks up and consequently the more output current that that field coil will generate. The other field coil is controlled by an external switch (your light switch). It is fed a constant current from your battery and generates a constant output current variable only by rpm. This output current was originally designed to handle the increased electric draw that your lighting circuit placed on the generating circuit. The 3rd brush was to be adjusted to such a position as to generate an "average amount of current" that would keep the battery charged under "average conditions". In other words - trial and err. Crude but effective in a time when electric equipment was optional but totally unaccept in todays' world. Sounds to me like maybe your 3rd brush circuit has a problem. Jerry
