Grease For L Waterpump Grease Cup
cheg
07-15-2004 12:07:56
What type of grease should I put in the grease cup of my 1937 L Waterpump?
Thanks
Robert Pence
07-16-2004 19:25:45
 Re: Grease For L Waterpump Grease Cup in reply to cheg, 07-15-2004 12:07:56
I use lithium grease in mine; I think it's the long-time standard for water resistance. You should still be able to buy it in a farm supply store in the mini cartridges. Actually, you can use it on just about anything. Dad used to use it in the lower unit of his outboard motors, I think.
Paul f
07-15-2004 15:56:27
This is a hard one as mentioning water pump grease at an auto supply store usually results in blank looks. Interestingly enough my other hobby is an M37 (Military 3/4 ton truck) which also has a grease cup on the water pump. Much discussion on that web site about water pump grease and the most popular answer was to use something called corn-head grease. ( I am not a farmer but apparently it is available at Farm Supply stores...Failing that boat trailer axle grease was second choice...
Paul f
