Shims for belt pulley housing on VAC
John Mc
07-15-2004 05:40:51
I am installing a belt pulley housing on a VAC that did not originally have one. The one I removed from another tractor has numerous shims for setting the gear clearance. How do I determine how many shims to use or get the right gear clearance?
Paul f
07-15-2004 06:48:36
 Re: Shims for belt pulley housing on VAC in reply to John Mc, 07-15-2004 05:40:51
"For field installation of the belt pulley housing, the correct backlash of the belt pulley gears is obtained by inserting or removing shims between the housing and the torque tube. The correct backlash is between .004 and .008 inch, which is approximately a movement of 1/64" on the rim of the belt pulley."
John Mc
07-15-2004 07:04:51
 Re: Re: Shims for belt pulley housing on VAC in reply to Paul f, 07-15-2004 06:48:36
Great, thanks for the info.
JohnM
07-15-2004 08:51:01
 Re: Re: Re: Shims for belt pulley housing on VAC in reply to John Mc, 07-15-2004 07:04:51
And that is with the set screw all the way down correct? Mine is still 1/4 inch away from the pointed part of the set screw going into the hole, and that is with a whole bunch of shims.
