Case 830 injection timing
Lucas Brown
07-14-2004 20:11:57
I would be gratefull if someone will decsribe the specifications and procedures involved in timing the injection pump to case diesel engine 4cyl 830 comfort king. Thanks
Jim Handke
07-16-2004 14:20:50
 Re: Case 830 injection timing in reply to Lucas Brown, 07-14-2004 20:11:57
830's are timed at 29 degrees BTC. Rotate the crank until the marker sits on top of the 29 degree mark and remove the plug at the front of the injection pump. There should be two marks showing in the hole. If not, rotate the crank one full revolution and the second one will show up. If the marks are not aligned, loosen the 4 pump mounting bolts and move the pump until they are aligned. Tighten the bolts and you're good to go.
