Case 500 injector pump
Walter
07-14-2004 17:08:44
Case dealer tells me my injector pump is putting fuel into the crankcase when we turn the engine over. He says it needs to be rebuilt (naturally). Is this something that I can do or can anybody suggest a reasonable place to have it done. What is a good price for a pump rebuild? Thanks!
John Saeli
07-14-2004 17:58:17
 Re: Case 500 injector pump in reply to Walter, 07-14-2004 17:08:44
A CASE man told me about a simple "O" Ring needing to be replaced when those PSB Pumps start doing that. It's an easy fix with the Pump in place. I forgot the procedure, but maybe someone will chime in....
Pat T
07-14-2004 17:52:50
They're probably telling the truth about the rebuild, this is getting to be a common ailment for those pumps. What you need to find out is if the dealer or whoever works on it has the replacement parts on hand, the American Bosch PSB parts are near impossible to find any more. I have always had my wallet lightened by at least $600 for injector pump work. It's possible it only needs a couple seals, the ideal situation would be to find someone who would replace ony those if that's all it would take.
