VAC-14 carburetor fuel level
Russ in WI
07-14-2004 14:08:13
Had a bunch of stuff in the fuel system, so I emptied the gas tank, put on a new sediment bowl, and took the carburetor off and cleaned it out real good. Before I took it off, it had gas up to where the bottom and top go together. After I put it back on, I have gas in just the very bottom of the bottom half. The tractor won't fire, and I'm getting spark to the cylinders. Did I goof up the floats? If so, what adjustment screw should I set? I need to get some hay out of the field before it rains again, should have just had someone a little more "tractor savvy" look at it.... Thanks -- Russ
mj
07-16-2004 11:11:01
 Re: VAC-14 carburetor fuel level in reply to Russ in WI, 07-14-2004 14:08:13
Did you blow out the gas line?
Russ in WI
07-16-2004 12:50:19
 Re: Re: VAC-14 carburetor fuel level in reply to mj, 07-16-2004 11:11:01
Yep. I must not have reset the floats correctly when I put the carb back together..... I should have time tomorrow before work to tear it apart again. Thanks -- Russ
