Case 55 Loader problems
Loren Andrews
07-14-2004 10:28:56
I have a Case 55 Loader on a David brown 885 tractor.
The loader will raise when the lever is pulled back but will not go down when pushed forward. Instead it will continue to rise. Does not creep when the lever is released.
Very unfamilier with hydraulics. Any advice?
Elmer
07-16-2004 04:33:25
 Re: Case 55 Loader problems in reply to Loren Andrews, 07-14-2004 10:28:56
Move your three point hitch lever forward, then try the loader again. That is if your loader is plumbed with a power beyond. Your three point hitch may be blowing over the relief valve causing the loader to raise. Oil take the path of least resistance. If this problem persists email me direct.
