Case 700 Tractor
R.J. Gerber, Jr
07-13-2004 14:32:41
Was there a three-point hitch configuration ever produced for this tractor? I'd love to be able to put it to better use (an implement or two? it does have a loader...)
If such an animal exists, where might I acquire one?
Thanks!
Don V.
07-14-2004 17:26:42
 Re: Case 700 Tractor in reply to R.J. Gerber, Jr., 07-13-2004 14:32:41
Forgot to mention the 400, 700 and 800 would all use the same stuff.
Don V.
07-14-2004 17:20:27
I have a 711 and a 712. 711 is row crop and has eagle hitch and the 712 does not. I just walked out to the shed and looked at both and believe the 712 {standard or orchard tractor} could be outfited for eagle hitch but would take a lot of work and a lot of parts. Looks like the fenders and floor plates would have to be changed as well. If you have a parts book for the 700 it should show exactly what you need. GOOD LUCK!!
ted
07-13-2004 21:11:27
Do you have Eagle Hitch at present, which is a type of 3point, and looking to modify it, or are you looking for a Eagle Hitch system to install on your 700??
caseman-d
07-13-2004 21:07:11
It depends on what model of 700 you have. Yes a row crop eagle hitch should bolt on to another row crop. If you have a standard 700 you would probably have to do some modifying on the tractor to make it fit. For the price of the one listed below you should jump on it as it is cheap. I priced one little piece that had been discontinue but still avalable and it was 83.00.
caseman-d
Lamont
07-13-2004 18:42:29
Yes they did come with the Eagle Hitch 3 point system. I just sold my lower lift arms on eBay. I've already sold the lift cylinder also. I still have a good rockshaft with upper lift arms, lower arm brackets, and the little lower bracket for the lift cylinder. All of it is good with no breaks or welds. I'll take $150.00 for it all. I don't need these parts. I'm building a pulling tractor. Let me know if you need them.
R.J. Gerber, Jr.
07-14-2004 15:04:36
 Re: Re: Case 700 Tractor in reply to Lamont, 07-13-2004 18:42:29
Lamont (and others who've kindly answered),
Do you know this assembly bolt up to my 700 without modification? How would I be able to tell? I can certainly post a pic of the PTO area if need be...
Lamont
07-14-2004 18:35:42
 Re: Re: Re: Case 700 Tractor in reply to R.J. Gerber, Jr., 07-14-2004 15:04:36
Email me a couple of pics of yours. Take pictures of the lower rear, right and left sides, where the hydraulic/pto unit bolts to your transmission housing. It needs to be where I can see how the floor boards attach to your trans housing. I'll look at my 400 Standard and see what it looks like. It should be the same. In the meantime if you'll email those pic's to [email protected], I'll take a look at yours too.
