SC
Larry
07-12-2004 17:29:23
Does anyone know what the number is of a 12 volt bulb that will replace the 6 volt bulb in the old 5 3/4" lights if one is available.
Campbell
07-13-2004 15:56:34
 Re: SC in reply to Larry, 07-12-2004 17:29:23
You might check www.topbulb.com. i got my six volt bulbs from them and I think they might have a similar 12V flange based bulb. I don't have any part numbers here at work, but that would be the place to check. Seems like they have every bulb known to man.
C. Amick
07-13-2004 09:51:38
It is the type of bulb that has the circular flange on it? If it is, you can use an 1156, if you are willing to take the flange off the old bulb and solder it to the new 12 volt ones. I have done this. I may have used J.B. Weld, instead of solder. You may also check the 1326 bulb. Try www.topbulb.com
Richard
07-12-2004 18:26:32
Larry I got 12 v lights at napa but they don't have the ring. I removed the ring used it on the new light.
