Case 451 Or 504 Engine, Here's The #'s
Jeff From WI.
07-12-2004 13:56:23
Hi all, & Let me say again Thank You For all Your Help. Head Casting #'s are A58522, Block # is A5851-3, There are Other #'s Below these #'s & They are 1-5-3-8-2-4, Oil Filter # is Baldwin BT-261, Fuel Filter is baldwin # is BF-896, Baush Case Fuel Pump # is A62571. Well that's all there is guys, What do you think now? Thanks Jeff From WI.
Roger
07-12-2004 20:03:08
 Re: Case 451 Or 504 Engine, Here's The #'s in reply to Jeff From WI., 07-12-2004 13:56:23
HEY JEFF!!!!! the A62571 is the only number that I could find in the "Where used" book, it shows that pump used on a 1070, so just going by that I would say it's a 451
Jim Handke
07-12-2004 18:51:56
Jeff: My 1070 has the same casting number, it's a 1973 model. The 1-5-3-6-2-4 is the firing order.
big orange
07-12-2004 18:47:03
Looked in the Baldwin book,451's and 504's could both use those fuel filters,A 1370 takes that oil filter,which is a 504,but a 1270 takes the same whick is a 451.Sorry I couldn't help.Still think it's a 504.My 1170 with a451 had a more rectangular water manifold,this ones more round like the 504 in my 2390.
Shane
07-12-2004 15:27:04
There should be a little tag on the left side of the engine just below the head farthest from the fan that should say either A451BD or A504BD. That will tell what engine. But with there being only one Baldwin 261 oil filter which is what our 1070's with the 451 use I would guess it is a 451. Of course maybe the non turbo 504 used just one filter too, I know the turboed 451 and 504 use two and they aren't 261's.
Jeff From WI.
07-12-2004 15:53:20
 Re: Re: Case 451 Or 504 Engine, Here's The #'s in reply to Shane, 07-12-2004 15:27:04
Hi Shane, The ser # tag is Gone. Shane it has Two Oil Filters Not One, My Fault I Didn't State that Sorry.
That should be RIGHT side
07-12-2004 15:28:01
