Case 830 - Main, Rod, and Head torque
Lamont
07-11-2004 21:21:17
I need the torque specs for the rods, mains, and heads for an LP Gas 830 Case. Also, I have bored the block to take 4 5/8" sleeves and flat top pistons making it 336 cubic inches. Original displacement is 284 cubic inches. My compression should be around 9.5 or 10 to 1. Should I go a little stronger on my headbolt torque or leave at factory specs? Thanks for your help !!!
MGM
07-12-2004 17:55:33
 Re: Case 830 - Main, Rod, and Head torque in reply to Lamont, 07-11-2004 21:21:17
Hey Lamont
If it's an A251 or A284 then my manual says
Mains = 145 to 155 ft lbs.
Rods = 95 to 105 ft. lbs.
Head torgue = 145 to 150 ft. lbs.
If its and A377 then book seems to show same torue specs.
If you need anymore info please email me at [email protected]
or [email protected]
Mike
Lamont
07-12-2004 18:46:36
 Re: Re: Case 830 - Main, Rod, and Head torque in reply to MGM, 07-12-2004 17:55:33
Thanks Mike ! That's exactly what I needed.
