Case 1200TK 4-WD 451 or 504 Engine? Help Please!!!
Jeff From WI
07-11-2004 18:31:44
Hi Guys, And Thanks to everyone who responded. I've Posted some pics in the Case Photo shed of the engine that I can buy. Can you guys Look at them & tell me what it is? & Will This Engine Bolt Up To My Old 1200 4-WD TK? Thanks Jeff From WI.
Shane
07-12-2004 15:47:20
 Re: Case 1200TK 4-WD 451 or 504 Engine? Help Pleas in reply to Jeff From WI, 07-11-2004 18:31:44
Sorry but the pics dont help much. But that is a 90 series dash on the machine which would lead me to think it is a 504. The problem you will have though is whether the 1200 will take a newer 451/504 or if it will only take the older 451. The newer 451 and 504 will definately interchange but I am not sure if the older and newer 451's are the same bolt pattern.
big orange
07-11-2004 20:45:58
Check the oil filter number,504's and 451's took different filter #'s.Fuel filters could be the same on both engines.If it has Baldwin filters the oil filter for a 504 is B236,don't know for a 451.
big orange
07-11-2004 19:07:25
Going by the water manifold and the oil cooler looks to be a 504,but I agree with the other post that it should say on the tag above the starter.
Roger
07-11-2004 18:55:45
Jef, I looked at the pics & in the last pic of the right side, isn't there a serial number tag on the block just above the starter? unless it's missing, that should say what engine it is. I can't see from the pic if there is a tag there or not.
Jeff From WI
07-11-2004 19:42:15
 Re: Re: Case 1200TK 4-WD 451 or 504 Engine? Help P in reply to Roger, 07-11-2004 18:55:45
Hi Roger, I Hate to say It's Missing???
Roger
07-11-2004 20:14:53
 Re: Re: Re: Case 1200TK 4-WD 451 or 504 Engine? He in reply to Jeff From WI, 07-11-2004 19:42:15
Jeff, from another pic, what is the casting number on the side of the block ahead of the starter? or if it's possible to get a casting number off of a head I may be able to look it up in a " Service parts where used" book that I have or maybe in a Central Tractor catalog, I don't know if heads are the same on 451's & 504's
Jim Handke
07-12-2004 06:15:08
 Re: Re: Re: Re: Case 1200TK 4-WD 451 or 504 Engine in reply to Roger, 07-11-2004 20:14:53
My Ag Parts catalog says: 504 head is A138337, 451 is A33616.
Shane
07-12-2004 15:36:40
 Re: Re: Re: Re: Re: Case 1200TK 4-WD 451 or 504 En in reply to Jim Handke, 07-12-2004 06:15:08
There were several different 504 heads. Maybe even several 451 heads too.
Jim Handke
07-12-2004 20:16:02
 Re: Re: Re: Re: Re: Re: Case 1200TK 4-WD 451 or 50 in reply to Shane, 07-12-2004 15:36:40
I was able to look in our old parts book this morning and none of those numbers matched the ones in the Ag parts catalog. Who knows how many times the numbers were changed.
Jeff From WI.
07-11-2004 20:44:27
I'll Have To Go And Look Tomorrow ok? Thanks Jeff.
