vac front end loader
steve
07-11-2004 06:25:29
I took my front end loader off a couple of years ago to install a engine rear seal. Now that i finally completed that I'm having a hard time figuring out how to hook the hydrolics back up for the loader. The pump is a David Bradley with a integrated tank. I have been able to hook it up so it will go up ok however, when i let it down the fluid leaks back through the breather. Thinking I had too much fluid i let some out only too find that it continues to leak through the breather...to the point where theres not enough to raise the bucket.I'm thinking there may be a return line that needs to be hooked into the line(?)...on the bottom of the pump is a fitting that is plugged.Maybe this should be tied into the line(?). Any help would be greatly appreciated.
ted
07-12-2004 05:29:35
 Re: vac front end loader in reply to steve, 07-11-2004 06:25:29
I am not familiar with that kind of pump. It was sold by Sears and I suspect made by Char-Lyn, but I don't know. Anyway, I would assume you have single acting lift cylinders. Right? That's one hose at the bottom of the cylinder and no down pressure. Right? If so, then there is no separate return line. Now if you have double acting lift cylinders, then you need the return hose and your pump would have a two way valve. You could just have the hose hooked up to the wrong port?? LOL
steve
07-12-2004 12:32:46
 Re: Re: vac front end loader in reply to ted, 07-12-2004 05:29:35
Thanks for the response. Yes the pump was sold by Sears and it does have single acting pump cylinders. The pump has a line on the bottom and one on the top. I first had it connected to the bottom and the pump wouldnt do anything...in fact when i engaged the valve to lift the bucket it labored the engine. I then hooked the hose to the top port(and plugged the bottom port) and it now works....well except now when i lower the bucket the fluid comes out of the breather. Thinking i had too much fluid in it i drained some but it kept coming out....frothing fluid infused with air. I then drove the tractor around putting the bucket up and down thinking it would stop when the right amount remained. What a mess. Now however there is apparently to little fluid as the bucket will only go up half way, slowly. Perhaps i'm doing this all wrong? I know air in the lines have to get out...so maybe it needs to be bled while being filled? Maybe the bottom port needs to be T'ed into the line with the top port?..but wouldnt that just feed the fluid back into the resevoir instead of into the cylinders? I'm quite hydrolically challenged. Thanks again.
