DB 1210 3 Point No Position Control Function
Gregg
07-10-2004 19:30:55
Hello Everyone, I am tring to fix the 3 Point on my 1210, The position control will not work on it, It seems like it is stuck in the "TCU" function, If you push the depth lever back you can here the hydraulic pump squeal, It will lift but it goes to the top of it's travel unless you modulate the control lever, it then sinks slowly, This tractor has the auxilary hydraulic control valves on it (I added them off a junk tractor)and they seem to work fine the pump is strong but no matter where i set the selector valve (TCU, Depth, ? Can't remember the 3rd setting) it acts the same, Any Ideas?
Thanks for your time :)
Elmer Landman
07-11-2004 05:13:36
 Re: DB 1210 3 Point No Position Control Function in reply to Gregg, 07-10-2004 19:30:55
Sounds like the selector fork has broke inside on the linkage. The raise lever has to be all the way back against the spring before you move the selector lever. The right ramshaft bracket has a cover on it that has four Phillips head(#3)bolts that retain it. Remove that cover and look in the bottom of it. Move the selector lever and see if the linkage in there moves back and forth sideways.
Gregg
07-11-2004 07:22:50
 Re: Re: DB 1210 3 Point No Position Control Funct in reply to Elmer Landman, 07-11-2004 05:13:36
Well after closer inspection I found that if I turn the selector knob to any other setting then TCU the hydraulic pump is squealing (relief valve opening) No matter where I set the position lever at. I hold the posistion lever all the way to the rear or raise position while turning the knob, Do you think it is still the fork Elmer?
The tractor is up at our cabin now so I would like to bring what parts I might need up to it when I go 1 hr drive, But I understand that might not be possible either but thanks for your help!
