Loader for a VAC-14?
Russ in WI
07-09-2004 14:50:40
I have the opportunity to purchase a Massey Ferguson trip-bucket loader for $75. Anyone know if it will fit on my VAC-14, and if it does, will I wreck the tractor by using it? I'm just not sure it has enough power for it..... I have an Eagle hitch and PTO. Thanks in advance -- Russ in WI
ted
07-10-2004 04:40:42
 Re: Loader for a VAC-14? in reply to Russ in WI, 07-09-2004 14:50:40
Given a welder, torch, and a pile of scrap iron you can make anything fit. The question is will the VAC carry the load? The weak point will be your wide front end, I assume you have one?? You can stack up some suitcase weights or a block of concrete on the back. But within limits, it will be a handy machine, you might wish it had power steering if you put too big a bucket on it.
Ryan
07-09-2004 15:47:22
I wouldn't get too big of a bucket. The steering on my VAC-14 is pretty easy right now, but all bets would be off with a good size front load on.
ryan
Russ in WI
07-14-2004 14:12:29
 Re: Re: Loader for a VAC-14? in reply to Ryan, 07-09-2004 15:47:22
Thanks for the replies. I've decided not to mess with the loader. Such a pretty girl without it. Plus, this way I can try to talk Ma into letting me have another, bit bigger, one..... Russ in WI, picking the neighbors flowers for Ma tonight
