995 Hydraulic System
Andy
07-08-2004 00:30:27
Hi Guys,
I have a 995 with a hydraulic changeover block below the seat on the left hand side. This transfers fluid from the 3 point linkage ram to the external rams on my loader.
This lever is a pain i.e if using the 3 pt and needing the front loader I have to move the changeover lever then set the raise/lower to raise THEN use the FEL lever....
Is there any mods I can make that will allow the hydraulic pump to run the 3 pt AND the FEL at the same time?
Is there any reason I shouldn't make mods to enable that to happen?
Thanks for any help.
Elmer
07-11-2004 05:15:56
 Re: 995 Hydraulic System in reply to Andy, 07-08-2004 00:30:27
You can add a power beyond to your system. I have a picture of one on my web site www.davidbrowntractortips.com
