David Brown 990
Garry
07-07-2004 09:45:00
I have a 990 that I need help with. It is a 1969 model I was told. The remote hydraulics work but the lift does not. The pump must be working since the remotes work but why is the lift not working. The transmission fluid is full and clean. any help is appreciated. I intend to get the manual but have had too much going on. thanks
James
07-07-2004 16:46:22
 Re: David Brown 990 in reply to Garry, 07-07-2004 09:45:00
Make sure the transport lock on the left lift arm is not engaged.
We need more info.
If the 'search' feature is working here, do a search including the name "Elmer", he has explained every situation at least once in the past.
Tony
07-07-2004 13:48:30
Let me know what you find out...my 1190 case is doing the same thing
