300 high low shift
Dave A
07-06-2004 16:26:21
Just put a new clutch in my 300,everything new or reconditioned but still slips when pulling a load.Can anyone tell me what I need to do?Does the high low have a Clutch and how do you adjust it?Thanks,Dave
Coloken
07-07-2004 12:28:13
 Re: 300 high low shift in reply to Dave A, 07-06-2004 16:26:21
No, the "high-low" does not have a clutch. It is a gear shift. There is a foot clutch at the engine. Is this the one that is slipping or is it the transmission clutch slipping? Transmission clutch is hand lever and a "over center" clutch that requires adjustment some times.
Lincoln
07-06-2004 18:06:05
Are you refering to the hand clutch on the left side of the tractor? Pushing it forward should engage the clutch and pulling it back should disengage it. There is a procedure to adjust it. I may be able to email the page from my manual if this is what you are refering to.
Dave A
07-07-2004 05:13:46
 Re: Re: 300 high low shift in reply to Lincoln, 07-06-2004 18:06:05
The 300 has a foot clutch with a high low range transmission.Dave
Lincoln
07-07-2004 18:07:43
 Re: Re: Re: 300 high low shift in reply to Dave A, 07-07-2004 05:13:46
Do you have the dual range transmission with the shuttle shifter? This would give you eight forward and eight reverse speeds. This set up only has the main engine clutch. The other set up has a tripple range gearbox with a foot clutch and a hand operated transmission clutch.
Dave A
07-08-2004 05:52:08
 Re: Re: Re: Re: 300 high low shift in reply to Lincoln, 07-07-2004 18:07:43
Lincoln,It has the triple range gear box and hand and foot clutch system.Dave
Jim Perry
07-25-2004 14:25:30
 Re: Re: Re: Re: Re: 300 high low shift in reply to Dave A, 07-08-2004 05:52:08
Lincoln, If you have an operators/owners manual for a Case 350. I sure would appreciate a copy. I'd like to know how the left lever and right levers on my Case 350 are *supposed* to work!!
Lincoln
07-08-2004 16:17:24
There is a proceedure to adjust the hand clutch. I would guess this is the problem. I don't have a scanner but could email a photo of the paragraph in the book if it will will help. Un hide your email addres and I will send it.
