HELP!! 990 is stuck in the woods!
Jay Dingwall
09-17-2006 13:40:07
Hope someone can enlighten me here, so I can get my tractor back in the yard! I have a Case/DB 990 (year unknown... sixties somewhere I think) and there is no pressure to the injectors. I was driving it and it started to bog like it was out of fuel so I shut it off. Checked the fuel level and now it won't start. There is plenty of fuel making it to the injector pump but only a few drops coming out of the pump when I take the line right off it... Help Please Guys!
Don McDowell
09-19-2006 19:56:15
 Re: HELP!! 990 is stuck in the woods! in reply to Jay Dingwall, 09-17-2006 13:40:07
Sounds kind of silly and may not be related at all, but make sure your air intake is not blocked. One fall my 990 would start fine cold and run fine until I got 50-100 yards from the shed and then die like it was out of fuel. I would bleed the fuel lines, mess with it and mess with it and finally it would start only to do the same thing shortly.
I found that mud dobbers(?)had gotten past the screen on the air intake and had eventually plugged the pipe down to the oil bath with a mud nest. As soon as I cleaned it out it ran great.
Don
loa
09-17-2006 17:51:52
try to pump your lift pump if it has one.
