steering issue with a 75 case 580B
sam
07-06-2004 06:33:22
I am looking at a case 580B with 2500 hours on it. The condition is good overall thou the steering is sluggish with a full bucket of material raised up. Any ideas or what to expect for repairs would be appreciated.
Roger (Mi)
07-06-2004 20:59:16
 Re: steering issue with a 75 case 580B in reply to sam, 07-06-2004 06:33:22
The power steering pump should squeal against a heavy load if it's in good condition. Check the flter inside of the reservoir. If it's plugged, replace it. Replace the TCH oil. The pump puts out 1500-1700 PSI. If the relief doesn't open at that pressure, you will need to replace the pump.
