CASE 600 GAS
TJ
07-06-2004 06:00:23
HI LOOKING FOR ANY HELP ON THE FIRING ORDER FOR A CASE 600 GAS TRACTOR THAT SOMEONE PULLED THE WIRES. IT BEEN SITTING A ABOUT THREE YEARS IN A BARN. THANKS
Lincoln
07-06-2004 17:51:30
 Re: CASE 600 GAS in reply to TJ , 07-06-2004 06:00:23
Firing order should be 1 3 4 2.
TJ
07-07-2004 07:12:26
 Re: Re: CASE 600 GAS in reply to Lincoln, 07-06-2004 17:51:30
THANKS GOT IT FIRED UP TO MOVE IT NOW IS THE BIG QUESTION. ON THE FRONT PANEL IS 600, BUT ON THE ID PLATE IS MODEL 611B. IT ALSO HAS CASEOMATIC ON THE TRACTOR ANY IDEA AS TO WHAT ALL THIS MEANS. IS THIS A GOOD TRACTOR? OR JUST A YARD DISPLAY. AND IT IS A FOUR POPPER!!!!
leland
07-06-2004 21:16:43
I thought a 600 had 6 cyls not 4
Jim Handke
07-07-2004 11:16:36
 Re: Re: Re: CASE 600 GAS in reply to leland, 07-06-2004 21:16:43
Case made a frightful decision and designated the 400 & 600 series twice. The big 400 had a 251 c.i.d. engine & big 600 a 377. They followed that with the smaller series, with case-o-matic trannies, with the 188 c.i.d. engines.
TJ
07-08-2004 05:58:17
 Re: Re: Re: Re: CASE 600 GAS in reply to Jim Handke, 07-07-2004 11:16:36
THANKS FOR THE INFO. NOW THE HARD PART COMES LOOKING FOR PARTS, HERE IN OHIO . NOT TO MANY PEOPLE KNOW ANYTHING ABOUT THIS TRACTOR. MOST OF THE TRACTOR PLACES JUST GIVE YOU DUMB LOOKS. BUT I'M NOT GIVING UP. IF THERE IS A GOOD PLACE FOR PARTS LET ME KNOW PLEASE. THANKS
leland
07-07-2004 18:02:25
Jim i saw a 600 gas in junkyard i swore itwas a 6 banger i guess i was wrong looked at to many old tractors to keep track
Jim Handke
07-08-2004 07:03:27
 Re: Re: Re: Re: Re: CASE 600 GAS in reply to leland, 07-07-2004 18:02:25
The early 600's came in LP also. Would it have been one of these.
leland
07-08-2004 08:47:23
 Re: Re: Re: Re: Re: Re: CASE 600 GAS in reply to Jim Handke, 07-08-2004 07:03:27
Jim no it was a gasser had a cracked block the guy also has a diesel that he uses to drag cars around his junk yard.
