anybody pulling a case 800
jeff
07-05-2004 19:44:02
looking for a set of propane heads and any pulling tips anyone might have for my 800 gas ist season pulling it finishing in the middle of the classes 6000 7000 8000 seems to like 8000 best i might try 9000 havent tried pulling in converter drive yet anybody tried??? thanks jeff
Lamont
07-06-2004 08:49:31
 Re: anybody pulling a case 800 in reply to jeff, 07-05-2004 19:44:02
See your other post for info on a complete LP engine. I'll have to check with my dad for price but will probably be CHEAP! We don't need it. I'm building a pulling tractor, 336 cubic inch gas 700 CASE. Email me at [email protected] or call me at 501-344-8026. Thanks,
Jeff Sanford
caseman-d
07-05-2004 20:55:34
I pulled a Case 801B for 2+ years. I pulled it in the 8500 and 9500 lb classes. I tried it in the 7500 lb class and just kept spinning out. I started out with 15.5-38's and then switched to 18.4-38's and I still spin out. I found out that I did better pulling in 2nd in the 8500lb class and 1st in the 9500lb class. I never had a power problem. I always pulled in direct, in low gear I could just idle down the track.(Semmed more like crawling).
caseman-d
jeff
07-05-2004 21:15:56
 Re: Re: anybody pulling a case 800 in reply to caseman-d, 07-05-2004 20:55:34
yea i spin also no power problem i pull 3rd gear in 6000 7000 2nd in 8000 havent tried 9000 yet but it likes 8000 im beating a lot of the so called stock!!! r deeres everbody knows therr 95-100 hp and im stock im running 15.5s but thinking 16.9s on 16 rims thats as big as we can go 1 size over.Never tried caseomatic thogh? i pulled an la for a couple years but just couldnt get passed finishing middle of the pack at least now im starting there ....what do you think about yhe propane heads????any more tips thanks jeff in maryland
caseman-d
07-06-2004 20:55:56
 Re: Re: Re: anybody pulling a case 800 in reply to jeff, 07-05-2004 21:15:56
As for the LP heads, if you can find some cheap as in the post above and have the money go for it. Not sure if that would give you enough power to go another gear higher. Since you are thinking of going LP heads I assume it's a gas you have. Not sure what all your rules are but I hung weights on the eagle hitch arms for the 9500 lb class, for the 8500 I have wheel wieghts bolted on so I went back to try the 7500.00 class. I did make the mistake of trying 4th in the 8500lb class once, it was bad lol. Let us know what you decide. I think my email adress is active so feel free to email me. Will help if I can.
caseman-d
