Case 530CK Brake Problems
Jason Weir
07-05-2004 10:06:20
I've got a 66 530CK with brake problems.
When I hit the brakes, the right side locks up immediately. Sometimes it will lock up without any brake applied. I have to reverse direction to get it to unlock. It does it in both forward and reverse. I have no problem with the left side. I've had both sides apart, cleaned & adjusted, made sure they were installed with the correct side inboard. Both sides slide easily on the splines. I've replaced the steel balls, springs and the brake linings, none of this has made any difference.
Any ideas?
Thanks
Jason Weir
Roger (Mi)
07-06-2004 20:10:57
 Re: Case 530CK Brake Problems in reply to Jason Weir, 07-05-2004 10:06:20
If all of the springs are NOT streched or rusted, the last remaining thing to look at are the surfaces where the linings make contact. They MUST be totally free of rust and must shine. Otherwise, the brakes will hangup or chatter.
gwinnibarge
07-06-2004 11:18:11
Check to ensure that the brake return spring for the right side is still there. The spring ensures that the brakes disengage while your foot is not pushing the brake.
On my 580 CK, the springs are underneath the tractor beneath transmission case. Theres a spring on both sides, if one is gone it should be evident. I've lost then when I've gotten stuck in the mud and the syptoms are similar to those you mention.
Hope this helpful.
Jason Weir
07-06-2004 12:25:41
 Re: Re: Case 530CK Brake Problems in reply to gwinnibarge, 07-06-2004 11:18:11
Both springs are there, I thought they might be weak and replaced them when I replaced the rest of the stuff.
thanks
Jason Weir
Jes
07-07-2004 20:34:40
 Re: Re: Re: Case 530CK Brake Problems in reply to Jason Weir, 07-06-2004 12:25:41
Hi Jason, not sure if your 530CK is the same as my 580CK, but I had the same problem and ended up replacing the discs and steel balls as the grooves that the balls run in had worn to the point that when they reached a certain point, they wouldn't roll back when the pedal was released. Worth a look if you haven't already found the cause. I bought new discs after a near rollover when one side locked up while travelling downhill. Regards, Jes
