VAC sleeve removal
Tom
07-05-2004 05:42:18
I have a VAC the motor was stuck I managed to remove 3 of the pistons but # 4 is stuck. I was able to pound the piston down so the piston is at the bottom of the cylinder. Is there anyway I could get the whole sleeve asembly to come out. The piston will not budge anymore. It wont go down as the rod is in contact with the crank and I cant get it to move up at all. I have been soaking it with various oils for several weeks now. Any info would be appricated. I have removed sleeves before but not with the piston stll installed. Thanks.
jeff
07-05-2004 08:37:37
 Re: VAC sleeve removal in reply to Tom, 07-05-2004 05:42:18
try placing a bottle jack under the engine and find a bar or rod or 2x4 to put against the sleeve and jack it out this works for me most of the time.....
Tom
07-06-2004 08:27:11
 Re: Re: VAC sleeve removal in reply to jeff, 07-05-2004 08:37:37
Jeff: I tried that even put a large 4X4 on top of the block and pounded down on it with a sledge while it was jacked up. Would it do any good to heat the sleeve up with a tourch?
