VAC engine question
Steve from PA
07-03-2004 18:11:37
I am in the middle of restoring a '47 VAC and while i was disassembling the engine, I noticed that in between the cylinder sleeves at the narrowest part of the block casting, there were hairline cracks connecting all of the cylinder bores. Is this a major problem, Is this something that's common, and would it be dangerous to rebuild and run the engine without repairing the cracks? Can this problem be repaired in a durable fashion i.e. by grinding out and welding the cracks? Any and all advice is greatly appreciated. Thanks in advance for all of your help.
DKase
07-03-2004 19:14:18
 Re: VAC engine question in reply to Steve from PA, 07-03-2004 18:11:37
Don't worry about the cracks. They are quite common. As long as the cracks are only on the top end of the sleeves they do not hurt a thing. The top of the sleeves are what seals to the head gasket so nothing will leak. If the cracks are on the bottom end of the sleeve where the o-rings seal into the block you have big problems, and you will have antifreeze in the oil.
