Need case 580F 4WD front end
Jim Carlson
07-01-2004 14:58:50
I need a front end for a case 580F 4WD backhoe. Can someone leed me to a good place for parts. If I can't find a front end, can someone tell me where to get all of the bearings so I can rebuild it?
Thanks a lot for your time
Jim Carlson
leland
07-06-2004 21:29:33
 Re: Need case 580F 4WD front end in reply to Jim Carlson, 07-01-2004 14:58:50
there is a place in Wolf Lake ILL that parts out a lot of case back hoes only problem for you it bis in deep southern ILL along mississippi river
Jim Carlson
07-03-2004 06:52:10
Ok, here is what I could find on the front housing. The casting number on the housing is 18251, the plate that holdes in the chunk has a number of "N9" ontop of the numbers 14413. The bearing on the outer shaft has a number of 6208 RSR.
I'm not sure if this will help, let me know if you need anymore info.
Jim Carlson
JimKS
07-01-2004 20:39:58
Um... I've never heard of a 580F... do you mean a 580E? Or a 480F?
I rebuilt the front end on a 580E a few years ago. The axle housings and steering knuckles were all torn up where the steering knuckle bearings came apart. Had to get the housings from a junkyard halfway across the country, got the bearings and seals from Case.
Jim Carlson
07-02-2004 17:54:55
 Re: Re: Need case 580F 4WD front end in reply to JimKS, 07-01-2004 20:39:58
I'm sure it is a Case 580F. From what I have found it was built in france and imported to Canada, but was NEVER intended to come to the USA. My boss bought it from a farmer in south Ga. Go figure?
It is a David Brown motor, but I haven't been able to get over to the front end to get any numbers from it. I will post them as soon as I can.
Thanks so much for the replies.
Jim Carlson
