diet for a case800
Jake
06-30-2004 20:38:19
I have a diesel 800 case case-0-matic that needs to go on a diet and I only have a short while. I am wanting to get it down to 5500 pounds. Is it possible? Right now it weighs 7220. It has a narrow front, eagle hitch and spin out wheels. I also have about 300 lbs of fluid in each rear tire that is going to come out. That is 600 lbs that can be removed easily.
I am planning on removing the entire eagle hitch and hydralic resevior. Any ideas on what else I can get rid of to lose a little weight. thanks Jake
Butch/ OH
07-01-2004 20:51:39
 Re: diet for a case800 in reply to Jake, 06-30-2004 20:38:19
You can do it, but I think you'll have to go to tin rims all the way around. We have a 700 that just weights 5000 with light 6 bolt hubs and tin rims on front, no 3pt. light seat and frame, cut off axles with 9 bolt flange welded to axles, tin rear wheels with 15.5 38 rears. Still has PTO and hydraulics. I think the Casomatic tractor will weight a little more and if it's a diesel a little more yet
caseman-d
06-30-2004 21:17:58
Why, I found my 800 pulled best in the 8500 and 9500 lb classes, I tried it at 7500 but it just spun out.
caseman-d
PS: you will really have to strip it if you want to get that light.
jeff
07-04-2004 21:22:51
 Re: Re: diet for a case800 in reply to caseman-d, 06-30-2004 21:17:58
caseman-d you pull your 800 in caseomatic any ive been scared to try and missed test and tune this year
jeff
07-04-2004 21:19:12
i dont think you will get that light im 250 and can only get my gas 800 down to 5875 and like already said mine pulls better 8000 and up
