case D530 questions
Grams
06-29-2004 18:00:47
I bought a backhoe that Ive been having some problems with. When I bought it the radiater leaked out of the overflow bad, tore it apart, and the head gasket was fine, the head was straight, and not cracked. I had a crack in an injector sleeve though. So I figured this must be the place where I was loosing compression. I got the sleeve replaced and ordered new gaskets but now my head gasket doesnt fit the holes in the head perfect, What I'm wondering is when I looked at the serial and model numdbers they dont make sense, serial # 8269458 model# D530, also cast on the engine is D165. Does this mean the backhoe and loader (model 32) are added to this tractor later? or is it original? Can anyone give me Info on the D530, where to get gaskets ect..Or what the difference is between it and the CK. On the intake manifold the casted # reads A35732. SORRY MY MESSAGE IS SO LONG, I would appreciate any replies. Thank You All.
ted
06-30-2004 05:01:46
 Re: case D530 questions in reply to Grams, 06-29-2004 18:00:47
It sounds like you were getting pressure into your cooling system. That is usually a head gasket or cracked head, but could also be a sleeve problem. I don't think your injector sleeve could pressurize the cooling system could it? Did you take off the radiator cap and observe any bubbling in the coolant when the engine was running? If so, I think I'd look further before bolting it back together, something was leaking. Otherwise, was the leaking continuous? If not, it may have been simple heat expansion. Did you look at the radiator cap? It could be that simple. Anyway, I wish you luck. Nothing is more frustrating than spending a bunch of money to solve a problem and then not finding the cause.
Dennis/Ohio
06-30-2004 03:58:16
Hi, I'm sure this info is in the archives too but yours is original and same loader & hoe as CK. A recent posting mentioned a cracked liner causing compression in cooling system? Best wishes, Dennis.....
