VAC-14 parts
Russ in WI
06-29-2004 12:49:06
I purchased a wonderful 1954 VAC-14 this spring and need a couple parts. There is, on e-bay, a clutch pedal for sale. Is the clutch pedal the same on all VA series tractors? I also busted the sediment bowl and need a new original one of those, actually I need the tensioner contraption underneath it. I tightened it too much. Any ideas? Thanks in advance -- Russ in WI
Joe (Wa)
06-30-2004 12:07:41
 Re: VAC-14 parts in reply to Russ in WI, 06-29-2004 12:49:06
If you have the original sediment bowl Case part numbers:
Bowl ... A11209
Bail ... A11212
Adjuster nut ... A11210
The bowl & nut are avail from Case. I am not sure about the bail, haven't had to buy one.
Joe
C. Amick
06-30-2004 10:02:25
There are usually a bunch of VAC parts up for auction on this site as well. V a l u - b i l t Tractor Parts also carries replacement sediment bowl assemblies. I don't think you can buy the tensioner contraption separately, though.
ted
06-29-2004 17:48:21
You can get new sediment bulbs off the IH site. Should work. Take a look at:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=50920&item=3823913083&rd=1
