Anyone bush hog with a DC?
JDB
06-29-2004 10:43:23
I'm thinking about a bush hog for my DC. It has Eagle hitch and remote hyd. Problem is to be a CAT hitch the top link needs to be where the PTO shaft is. I can get around this OK but the drive shaft angle will be fairly steep. Would rather avoid the whole problem by getting a 6 or 7 foot 2 spindle pull type. It will not be as manuverable but will do what I want it to do. What's your experience bush hogging with a DC?
John Saeli
06-29-2004 18:57:29
 Re: Anyone bush hog with a DC? in reply to JDB, 06-29-2004 10:43:23
Hey JDB: I Bush-Hog with both my '53DC & '53SC. I use the top link mounting thats up on the top of the PTO Housing. It won't pick as high as if I was using the PTO Cover Top Link Mounting, but I don't mind. The PTO Drive-line angle is no problem.
C. Amick
06-29-2004 11:56:23
I don't know if this is any help, but I use a 5ft. pull type bush hog behind my SC. One advantage to the pull type over the 3-point hitch type is that it follows the ground contours a lot better if your ground is uneven. Make sure you buy a PTO overrun clutch if you don't have live PTO. I also have a 3-point hitch Vicon disc mower that I use on the SC. The PTO angle is not a problem, but my 3-point hitch is fabricated.
ted
06-30-2004 04:27:07
 Re: Re: Anyone bush hog with a DC? in reply to C. Amick, 06-29-2004 11:56:23
I prefer the control and manuverability of a mounted cutter, but then I am not as skilled as some in backing a pull type machine. The PTO angle has been a problem ever since the DC was built. They always have run on a frightening angle but as long as you keep your U-joints greased, the PTO works fine. I agree with John, use the high hook for the top link. think you'll be happy.
dbb62
06-29-2004 14:36:25
Is an overrun clutch the same thing I call a slip-clutch? I pull a 5 ft. drag mower behind my 48 S (not live PTO) and have had good luck with it. It has a shear pin, but no slip clutch.
ted
06-30-2004 04:48:59
 Re: Re: Re: Anyone bush hog with a DC? in reply to dbb62, 06-29-2004 14:36:25
The overrun clutch is different than a slip clutch, it slides on the PTO shaft and looks like an extension, but has a mechanism that allows it to free-wheel when you stop the tractor or pull the clutch to shift gears. It works like a ratchet on a socket set. You can purchase them at any implemment dealer. They sure save on gear grinding if you stop and shift into reverse often.
GeoMo
06-30-2004 05:00:33
 Re: Re: Re: Re: Anyone bush hog with a DC? in reply to ted, 06-30-2004 04:48:59
The overrun clutch can save your life.
Without one the brushog can push you into a ditch.
