Transmission oil slinger in a VAC
Robert Paris
06-29-2004 05:51:46
Recently I'm having problems shifting in forward gears after using the reverse gear. The shifter is often stuck in neutral. I opened the shifter cover, took a look inside and found that the oil slinger gear is badly worn out. What is the purpose of that gear ? Could my shifting problem be related to this or is it a matter of of the shifter rails and forks ?
Thanks for helping out.
mj
06-29-2004 10:06:34
 Re: Transmission oil slinger in a VAC in reply to Robert Paris, 06-29-2004 05:51:46
The oil slingers' purpose is to insure lubrication of the mainshaft gears/bearings, shift forks, and shift rods by keeping the grease moving upwards even when the countershaft is disengaged in neutral with the engine running. You could manually lubricate the upper components, install the cover/shift mechanism and test run the tractor to see if there is a change.
Robert Paris
06-29-2004 16:35:59
 Re: Re: Transmission oil slinger in a VAC in reply to mj, 06-29-2004 10:06:34
Thanks for answering. The trans diff oil level looks OK to me. It's at least one inch above the notch on the dipstick and everything seems to be soaked in oil. I suspect that ice might have damage the transmission last winter. I'll take off the shifter cover, rails and fork and check how everything works. Hope things turn out ok, I really enjoy my VAC.
mj
06-30-2004 08:51:02
 Re: Re: Re: Transmission oil slinger in a VAC in reply to Robert Paris, 06-29-2004 16:35:59
Good luck to you. Hope it's an easy fix!
