580B ring and pinion
Robby
06-28-2004 22:15:05
We have a 580B construction King that has a loud clanking noise coming from the rear end and the wheel kind of catches on something internal but will turn. Could this be a snap ring broken or something catching on the ring gear? Help...
Roger (Mi)
07-06-2004 20:37:50
 Re: 580B ring and pinion in reply to Robby, 06-28-2004 22:15:05
More than likely, there is a tooth missing on the side gear that drives the bull gear. It's a quick repair as compared to replacing the ring and pinion. Good luck.
Marc
06-29-2004 10:42:07
Robby,
Most likely broken teeth on the ring gear, the pinion or both. Click on the link below for a parts illustration of the final drive. Drain the fluid and pull the rear inspection cover to see what gave-up. The machine will need to be split to repair.
Doug in Amarillo
06-29-2004 10:39:35
The ring gear on the 580B were originallyriveted on.I have seen more than one that had the rivets work loose and come out.This is probably what happened to your tractor.To fix this you will have to replace the ring and pinion.The new ones come with a bolt on ring gear.Good Luck!
R Fink Sr
05-16-2005 05:34:20
 Re: Re: 580B ring and pinion in reply to Doug in Amarillo, 06-29-2004 10:39:35
Doug i have a 580b that has a clunk in the rear end could it be same problem. I don't know year ser.8698824. Is this a big job to fix will it need to be split. this is not a every day work machine gets used once or two times a month. A few hundred houres a year. Thanks
Please e mail be direct i don't get on site to often [email protected]
