Magneto Value
Ryan
06-27-2004 18:59:06
I just recently got an engine that I am going to transplant into my 53 VAC. (See Swather Post) The engine I got runs well and the magneto has a good strong spark and click. However, as my tractor came with an eagle hitch the mag has to go in favor of the distributor and coil. For that reason I plan on putting the mag up for sale. However, as this is my first tractor project I have no idea what it is worth. Any thoughts from you guys? I do not want to be laughed at when I post it.
Alberta Mike
06-28-2004 16:20:22
 Re: Magneto Value in reply to Ryan, 06-27-2004 18:59:06
Unless you really need the bucks, my advice is to not sell it. I don't know how many times I've sold something (or sometimes even thrown something out) and then down the road a year or so you'll need it for one reason or another. Say you come across a good deal on a tractor that needs a mag. Just tag it and store it, that's what I'd do.
Ryan
06-28-2004 20:06:21
 Re: Re: Magneto Value in reply to Alberta Mike, 06-28-2004 16:20:22
What else would this fit? I am not planning on having multiples of the same model.
Alberta Mike
06-29-2004 04:49:09
 Re: Re: Re: Magneto Value in reply to Ryan, 06-28-2004 20:06:21
Can't help with that question. I do know that many mags will actually work on other applications even if they weren't originally designed for that. For example, I have a Fairbanks Morse mag on my Case V that originally had a Spidorf-Edison mag. Also, I had a 101 Junior (finished and restored) and guess what kind of a tractor I found a couple of years later and bought? Same one, and it was missing the front mounted air cleaner. I had found another one earlier in a parts pile and eventually threw it out. What a mistake that was. Whatever you decide to do will be the correct decision I'm sure.
Bill
06-28-2004 06:40:02
Ryan,From the factory you could get the dist. or mag. If you wish to still keep the mag you can go to a dealer or junk yard and get the adapter so a mag would mount out the back of the hydraulic pump on the vac.I have seen good mag sell from 25.00 to 150.00 Put it on ebay and you will be surprise what you can get out of it. Bill
Ryan
06-28-2004 09:07:41
 Re: Re: Magneto Value in reply to Bill, 06-28-2004 06:40:02
Bill, You wouldn't happen to have a picture of what this looks like would you? I don't want to go to the dealer and seem like a moron.
ted
06-28-2004 00:33:53
I think it came originally with a mag, but if you want the distributor, then OK. I'd just put it up for sale on ebay with a low reserve. I've seen Ebay mags go for anywhere from $30 to $110. A good original, working, Case mag with no cracks should bring around $75.00+. Do you have the distributor and coil? I have a Case/Delco aftermarket distributor, off a DC, that I will trade for the mag. I think it should bolt right on to the VAC since the mags were the same.
Ryan
06-28-2004 06:06:05
 Re: Re: Magneto Value in reply to ted, 06-28-2004 00:33:53
Ted,
The reason that the mag has to go is that is where the hydraulic pump mounts on the engine. I have the old engine that the dist and coil should switch from but if any of them don't work I will let you know.
