Late model DC Serial Number
Glenn FitzGeral
06-27-2004 18:17:06
About six months ago I posted my DC serial number in effort to determine it's age. The number reads 6022592. Today I got the number off the original engine block. It is 592DC. Anyone know the year of my tractor? It was factory equipped with eagle hitch, live power, hand clutch, short wheel base wide front, 38' rear wheels. What year is my tractor? Thanks, Glenn F.
DCTOM
06-28-2004 07:04:45
 Re: Late model DC Serial Number in reply to Glenn FitzGerald, 06-27-2004 18:17:06
GLENN; THE FIRST DIGIT HAS TO BE AN 8 I WILL LOOK UP THE NUMBER AND POST IT THIS AFTERNOON SOUNDS LIKE A 53 BUT WILL CHECK FOR SURE TOM
ted
06-27-2004 21:56:54
Glenn, DC Tom can tell you for sure, but I think you read your first number wrong. Sometimes those guys at the plant didn't hit the number die vey hard and it is difficult to read. It is probably an 8. I have a DC #8023224 That was built in Nov. 1952, which makes it a 1953. My guess is that yours is a 1953 as I also have a DC8042211 which is dated Sept 1954, but it has foot clutch.
ted
06-28-2004 00:47:48
 Re: Re: Late model DC Serial Number in reply to ted, 06-27-2004 21:56:54
Glenn, Correction, I should have said I think yours is a 1952. Do you have both brake pedals on the right side?
Glenn F.
06-28-2004 06:38:39
 Re: Re: Re: Late model DC Serial Number in reply to ted, 06-28-2004 00:47:48
Yes, both brakes are on the right. I should have paged DCTom but figure he'll be checking in. I am sure I am reading the serial number tag correctly in the first two digits being 60. The 6 has a 'fat' circle on the bottom and a rather small hook on the top, but there's no way it looks like an 8. I understand there's a problem with the number even if the first two digits were 80. How is the stamped number off the engine flange interpreted? Thanks, Glenn F.
DCTOM
06-28-2004 09:17:09
 Re: Re: Re: Re: Late model DC Serial Number in reply to Glenn F., 06-28-2004 06:38:39
GLENN; YOUR TRACTOR-- 8022592-DC4 WAS BUILT NOV 3 1952 AND SHIPPED TO PETERSON IMP. CO STANLEY WI. FEB 25 1953 IT HAD EAGLE HITCH YOUR TRACTOR IS A 1953 MODEL AS CASE USED OCT 31 AS A FISCLE YEAR END, ANYTHING BUILT AFTER THAT DATE WAS THE NEXT YEARS MODEL, THI FIRST DIGIT HAS TO BE A 8 AS THERE WERE NO 60 NUMBERS USED IN RACINE AS TO THE 592 ON THE BLOCK MOST TIMES THEY DIDNT STAMP THE COMPLETE NUMBER THERE JUST THE LAST DIGITS TOM
Glenn F.
06-28-2004 15:02:23
 Re: Re: Re: Re: Re: Late model DC Serial Number in reply to DCTOM, 06-28-2004 09:17:09
Thank you, Tom. Stanley is about 30 miles from where I bought the tractor. Interesting. Did they manufacture any DC's in '54, or only retooled '53s? Did they manufacture SCs later than DCs? Or was this a retooling situation too in order to sell them? 300 replaced the SC? Or VAC? Thanks, Glenn F.
John H-WI
06-28-2004 16:22:12
 Re: Re: Re: Re: Re: Re: Late model DC Serial Numbe in reply to Glenn F., 06-28-2004 15:02:23
Glenn, the 300 replaced both the SC and VAC. Was actually a VAC with a bigger motor and the triple range transmission. The only two things with the 300 was las lack of power steering and the rear end was the VAc rear end and it had trouble handling the extra power. We split our in two with the 3 bottoms behind it in the hills. If I remember right most 54 series D and S's were reworked.
