Negative or Positive Ground
Bob from Wiscon
06-27-2004 08:40:59
I must have heard ten different answers on negative or positive ground. Someone in the know please tell me which is correct. I have a 1945 SC with magnito 6 volt. Which ground do I use?
Thank in advance for your help.
Jerry W
06-27-2004 10:45:40
 Re: Negative or Positive Ground in reply to Bob from Wisconsin, 06-27-2004 08:40:59
Bob
Regardless of where your tractor was built you have to utilize the ground as specified by your voltage regulator/cut-out relay.
The regulator/relay is the only component of a point ignition/generator electrical system that is polarity sensitive.
Every other component can be utilized either way.
Jerry
DCTOM
06-27-2004 09:43:20
ALL RACINE BUILT UNITS WEERE NEGETIVE GROUND, ROCKISLAND WERE POSITIVE YOUR SC WAS BUILT IN RACINE TOM
Alberta Mike
06-28-2004 16:23:07
 Re: Re: Negative or Positive Ground in reply to DCTOM, 06-27-2004 09:43:20
Now that's some information that is interesting, negative ground on an old tractor. I wonder why Case did that. If I find the serial number from my friend's model S (wide front) is it possible that it might be either + or - ground too?
