VAC, 200 series, and 300 series
Steve from PA
06-27-2004 06:03:25
I have heard that the engines from the 200 and 300 series tractors were made from the same castings. Is this true? And if so, will the engines all bolt up front and rear to a VAC? On a different train of thought, A friend of mine has a Massey tractor data book that lists every detail you could possibly want to know about every massey tractor ever built. Is there such a resource for Case tractors? Thanks in advance.
C. Amick
06-28-2004 14:07:47
 Re: VAC, 200 series, and 300 series in reply to Steve from PA, 06-27-2004 06:03:25
I've heard that you can put the internal parts from a 200 or 300 series engine into a VAC block. I don't know if either block will bolt to a VAC, but I would guess, no. There is a book called "150 Years of J.I. Case", it's the most comprehensive book that I know of.
