Leather cup install
Rob
06-26-2004 10:19:46
Hello again. Thanks to Joe (Wa) I have my leather cup for my 49 vac. I am new at this any suggestion on how to get the cup in the housing without tearing it up? Thanks
Joe (Wa)
06-26-2004 14:33:08
 Re: Leather cup install in reply to Rob, 06-26-2004 10:19:46
Rob, it is important to position the cup relative to the inner wall of the cylinder.
To do that, put the cup and plate on the piston but leave the screws loose. Turn the cylinder open end up and push the piston in upside down. When the open end of the cup is even in the cylinder tighten the capscrews. Take the piston back out, lube and put it in cup down in the operating position.
Joe
Rob
06-26-2004 15:33:02
 Re: Re: Leather cup install in reply to Joe (Wa), 06-26-2004 14:33:08
Joe I am confused It is my fault my setup has the large 3.75 bore piston behind the seat. If that is what you are talking about then I am really confused
Joe (Wa)
06-26-2004 18:02:39
 Re: Re: Re: Leather cup install in reply to Rob, 06-26-2004 15:33:02
third party image
Rob, this is the hitch you have right? You have that cylinder with piston off the tractor.
Put the leather cup & plate on the piston but leave the capscrews loose.
Set the cylinder open end up. Push the hollow end of the piston into the cylinder bore toward the closed end. Push it in until the cup is in the cylinder bore equal distance all around as measured from the open end of the cylinder. Now tighten the capscrews on the plate and pull the piston back out.
You want to now install the piston in the operating position (exactly opposite of above) with the leather cup in the bore facing the closed end of the cylinder.
I'll see if I can post a pix from the manual showing the piston in the inverted position in the cylinder for tightening the capscrews.
Joe
Joe (Wa)
06-26-2004 17:57:34
Joe
Rob
06-26-2004 18:01:49
 Re: Re: Re: Re: Leather cup install in reply to Joe (Wa), 06-26-2004 17:57:34
I think i understand now that i stopped and thought about. Sorry. Thanks for all your help
Joe (Wa)
06-26-2004 18:07:13
 Re: Re: Re: Re: Re: Leather cup install in reply to Rob, 06-26-2004 18:01:49
I guess we are playing post @ the same time tag. Those cups are spendy so if you want a pix from the manual be happy to do it.
Joe
rob
06-26-2004 18:39:32
 Re: Re: Re: Re: Re: Re: Leather cup install in reply to Joe (Wa), 06-26-2004 18:07:13
if you would i would be very thankful. i was at looking at everything again. thanks
Joe (Wa)
06-26-2004 19:09:43
 Re: Re: Re: Re: Re: Re: Re: Leather cup install in reply to rob, 06-26-2004 18:39:32
Rob, I just sent you an email with the pix & instructions from the manual. Subject line is "Vac eagle hitch".
Joe
Rob
06-26-2004 20:57:21
 Re: Re: Re: Re: Re: Re: Re: Re: Leather cup instal in reply to Joe (Wa), 06-26-2004 19:09:43
Thank you so very much i finally got it together. I have heard several opinions as far as fluid for the lift system. What should i use i heard hydraulic fluid eats the leather cup. i dont know what is right. i use the tractor for bush hogging in the summer and pushing some snow in the winter. i live in north central ohio again thank you so much!
Joe (Wa)
06-26-2004 22:52:41
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Leather cup in in reply to Rob, 06-26-2004 20:57:21
Rob, when I was a youngster most hydraulic cylinders had leather cups. I spent 5 years on a WWII submarine during the 60's that had leather cups and seals in the A & B ends. We used hydraulic fluids. Off-road machinery like you tractor usually used low viscosity motor oil simply because it was readily available.
Joe
