Case 500 started
Walter
06-25-2004 19:45:13
we figured it out. The transfer pump obviosly
had water in it and set up a while, rusting the gears tight. When we turned
it over it sheared the pin on the drive shaft causing it not to pump. We
took it off, freed it up, made a new pin. Spun the engine engaged the
compression and the tractor busted off ! Smoked like a freight train but
ran. Thanks for the help.
Jerry (WI)
06-25-2004 21:06:33
 Re: Case 500 started in reply to Walter, 06-25-2004 19:45:13
Walter, now that wasn't so bad to look at primary pump was it? I had that same pin sheared off of mine too, but also the snap ring was gone and the gear stayed in pump. I liked how simple it was to replace the drive pin. good to see it going
