SC wiring diagram
Tod
06-25-2004 10:11:54
Hi! I'm looking a a wiring diagram for a 1950 SC - positive ground, 6 volt, with a distributor. I've got the Case book, but it really doesn't show the wiring to the coil, dist,... or where the lights get hooked in. Also, do I use 2 or 1 gauge for the battery cables?
Thanks in advance
Campbell
06-25-2004 17:41:42
 Re: SC wiring diagram in reply to Tod, 06-25-2004 10:11:54
Tod, I think there might be some in the archives of old posts since I'm pretty sure Mike Schotte posted a couple of them. If you don't find them shoot me an email with your address, because I have two in jpeg form that might help a little. Not sure if they're detailed enough but might be worth a shot.
C. Amick
06-25-2004 10:30:21
All SC's were negative ground with a magneto. That's probably the only wiring diagram you are going to find for an SC. A diagram for an old Farmall would probably be closer, if it's positive ground and has a distributor. No. 2 cable will work. I would use Size No. 1 cable. They are a little stiff to work with.
