overheating 411B while brush-hogging
Rick
06-24-2004 08:25:42
I've changed anti-freeze - circulating okay and all that. Brush hog is almost too big for this tractor, but i've had it for 3-4 years, and although engine warms up more than usual, it never has gotten to this point of overheating. Could it have anything to do with transmission case - I changed fluid this spring and it was recommended to me to use 85W-140 - but is too thick - could that be causing engine to work harder? Also, is there a tranny breather under the seat on these? Any ideas? thanks in advance.
BLR
06-26-2004 14:41:05
 Re: overheating 411B while brush-hogging in reply to Rick, 06-24-2004 08:25:42
If you put the 85-140 in the case-o-matic system that could be the problem. If it's in the gearbox it shouldn't be a problem. Is there any chance the front of the radiator and tranny cooler are plugged with dirt?
JohnM
06-24-2004 17:12:05
There is a breather right next to the clutch pedal on top of the case. 85/140 in the Tranny? Which fill plug did you use? That might be a little much, I will have to look it up. What size is the brush hog?
rick
06-25-2004 06:01:26
 Re: Re: overheating 411B while brush-hogging in reply to JohnM, 06-24-2004 17:12:05
It's a serviss - rhino or something - pretty heavy and 7' across as I recall. I also wondered about the crankcase breather.....
