VAC Proect: Eagle Hitch Pump Question
F-I-T
06-24-2004 07:16:35
third party image
Hello All:
I have a small, but significant leak at the engine-mounted Eagle hitch pump on my '50 VAC. It's leaking during use from the lowest point of the rear most seam. It only leaks during lifting. The parts book shows a gasket there (I'll bet it's a thin one).
Does anyone know if that gasket is available, or if not, how thick the material is? Or, can it be re-assembled using a proper sealant after lapping the surfaces flat? Or is that a really bad idea?
Thanks as always,
Frank-in-Tallahassee
bob missouri
06-25-2004 21:54:51
 Re: VAC Proect: Eagle Hitch Pump Question in reply to F-I-T, 06-24-2004 07:16:35
Frank, I had the same leak but could not come up with the gasket as parts house said it was not available {I have parts book}. I took blue silicone and spread it on thin, tightened bolts tightly and it has held with no problem. Do not try prematex form a gasket as I also tried that
with bad result. Blue silicone will work.
vacnut
06-25-2004 20:29:47
Hey Frank, After looking at your picture.. Why is your ground cable bolted through your starter mount?
F-I-T
06-26-2004 05:19:55
 Re: Re: VAC Proect: Eagle Hitch Pump Question in reply to vacnut, 06-25-2004 20:29:47
third party image
VAC Nut:
Yes, it sure is. I always try on 6 volt systems to get the starter the best source of hot and ground that I can. I just think it gives the 6 volt starter the best chance of performing well. So far I've never been disappointed.
What really helpd was the 980 CCA Optima battery!
Frank
JohnM
06-24-2004 17:13:25
 Re: Re: VAC Proect: Eagle Hitch Pump Question in reply to Joe (Wa), 06-24-2004 09:17:53
Don't get a much better answer than that do you Frank!
F-I-T
06-25-2004 07:28:55
 Re: Re: Re: VAC Proect: Eagle Hitch Pump Question in reply to JohnM, 06-24-2004 17:13:25
third party image
That's why I always ask the question here! Everybody on this board has had a hand in getting that old VAC back up and running!
Frank
