CASE 630 GAS TYPE??
J Mann
06-24-2004 06:52:16
Does anyone know how I can tell what type of gas my Case Series 630 takes? I suspect it is diesel, but how can I be 100% sure?
Coloken
06-24-2004 07:26:26
 Re: CASE 630 GAS TYPE?? in reply to J Mann, 06-24-2004 06:52:16
If the FUEL is uses is gas, it will have spark plugs. If diesel, it will have 4 small lines running from a pump on the side.
Please do not try to run it until some one that understands engines shows you how. This is meant in a friendly way and I hope you take it as such.
J Mann
06-24-2004 07:51:36
 Re: Re: CASE 630 GAS TYPE?? in reply to Coloken, 06-24-2004 07:26:26
You are correct - I mean't fuel :) - No offense taken :) - If what you have said here is true, then deisel it is! It also smells like deisel, I just wanted to be sure. thanks for your help!
