Biodiesel
Jim Handke
06-24-2004 05:59:07
This is off topic somewhat. My fuel supplier started selling biodiesel this year. They use a truck compartment for soy oil and mix it right at your tank. I use the 2% blend. I have seen ads that claim this will clean dirty injectors. Does anybody out there use biodiesel, and have you seen that this is true?
Roger
06-24-2004 06:52:08
 Re: Biodiesel in reply to Jim Handke, 06-24-2004 05:59:07
I have been getting 100% soydiesel for 3 years now & using it undiluted in 3 engines around here with NO problems.
DKase
06-24-2004 06:21:43
We've been using it in all our diesels for about 2 years now. 100% soybean oil is used as cleaning solvent in parts washers, so it does help clean things out some. There are a lot of guys running 20 to 30% in their engines. It takes 2% to get the lubricity up to where it should be from taking the sulphur out. It also lowers emissions. The over the road truckers that started using it 3 years ago said that the additional cost of the soybean oil is more than offset by the lower repairs to the injectors and injector pump. Now get out there and BURN OUR BEANS!!! (Not eastern oil)
leland
06-27-2004 18:54:21
 Re: Re: Biodiesel in reply to DKase, 06-24-2004 06:21:43
If you want free fuel surf the web and find the sites that tell you how to recycle vegatable oil , from fast food joints easy to clean up and rerefine in to fuel. know a guy that uses sunflower oil in his tractors (straight) and has no problems in winter he blendsfuel.so if you want biofuel its out there and free if you want to take the time to produce your own seems easy don't it.
