Timing on a SC
JC
06-23-2004 13:17:27
I am a novice engine mechanic to say the least. I need an idea of how to time the engine to the distrib. I had to replace my head gasket and pulled a few parts off for paint. I pulled the magneto off and am not sure if I lost my timing. When I put it back on and had the punch mark on the flywheel in the inspection hole my distrib. was in the third cylinder location. I though that in should be in number one position. Also, on the cylinders are they numbered 1 thru 4 when looking at them from the clutch side of the tractor. Thank You all in advance for your time. Like I said, I am a novice so the simplest explination would be the best.
Walter
06-23-2004 15:26:03
 Re: Timing on a SC in reply to JC, 06-23-2004 13:17:27
Turn engine to # 1 top dead center, put magneto in your hand and turn with plug wire in the #1 hole. When it sparks, stop turning it and bolt the magneto into the housing making sure the ears on the mag engages the drive coupling. You may have to turn mag ears a little more after the spark occurs to get it to line up but not so much as to make the mag fire again.
