SC sleeves
Steve from PA
06-22-2004 17:58:28
In the " Case tractor illustrated buyers guide", the author says that in the 1953 model year, the SC's bore was increased from 3 1/2" to 3 5/8". Do the sleeves for both of theese bores have the same O.D.? I have a '51 that does OK in the pulls, and I'm sure if I go with the lager bore, and loose some weight in the front end, I'll do better. Does anyone have any experience with this? I thought Mike Schotte had said that he does OK in the pulls with his. I'd love to hear all your comments. Thanks in advance. Steve
C. Amick
06-23-2004 06:39:45
 Re: SC sleeves in reply to Steve from PA, 06-22-2004 17:58:28
There were also 3-11/16" turbo domed aluminum pistons available for the Case SC (after market product). If you are going to spend money to upgrade, I would try to find a set of these.
Steve from PA
06-22-2004 18:44:51
Also, does anyone know how to find M&W parts?, I.E. pistons etc... And is there somewhere to get the sleeves, rings etc... Thanks again. Steve
L. Lamp
06-22-2004 19:07:52
 Re: Re: SC sleeves in reply to Steve from PA, 06-22-2004 18:44:51
Sleeves for the SC's are availiable from Case-IH and so are flat top aluminum pistons in the 3 5/8" bore. These sleeves are only availiable for the pre '53 engine blocks. I have a '54 with 3 5/8" sleeves with M&W pistons, and it won't spin out in low gear. I have Titan 11.2x38 on the rear and no weight or fluid. It weighs 4610 without me.
Steve from PA
06-22-2004 19:32:54
 Re: Re: Re: SC sleeves in reply to L. Lamp, 06-22-2004 19:07:52
Where did you get the M&W pistons? Also, what pressure do you run in the rear tires?
L.Lamp
06-24-2004 11:43:41
 Re: Re: Re: Re: SC sleeves in reply to Steve from PA, 06-22-2004 19:32:54
I haven't checked tire pressure, but I could be a little too high as the tires do not squash down much. The M&W pistons were an accident. A friend gave them to me after he took them out of a recently overhauled SC that the owner junked because the hub broke in the clutch disk. I had them about 10 years before I got an SC to put them in. I have the late carburetor and open it up to make it barely smoke black on a hard pull, but the power doesn't seem to be there. It also has the 5617a head with new valves and guides.
