930 Case weight?
Jed
06-22-2004 05:16:29
I just got a 930 case LP with a cab on it. Does anyone know what it weighs?
Dan J
06-22-2004 13:17:56
 Re: 930 Case weight? in reply to Jed, 06-22-2004 05:16:29
Jed, Nebraska test weighed the tractor in at 8845#. I pull a 930 Case and with the tires 1/2 loaded it weighs around 10,500#. Hope this helps, Dan
Jed
06-23-2004 05:34:46
 Re: Re: 930 Case weight? in reply to Dan J, 06-22-2004 13:17:56
Dan, Thanks for the info. I just got a 930 LP and when I winched it onto the tilt bed from the trailer, it dropped the truck bed significantly. So much so that the bed was touching the tires.
It has these massive rear wheel weights that look like the equivalent of about 4 Farmall weights per side. With these weights and the cab
it is heavy. The way it dropped my tilt bed I guessed at least 5 tons. It is more of a tractor than I bargained for. If you know anyone interested in a 930LP , please let me know. The price will be reasonable.
